S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
99 s420 antennae/windows
Old Jun 20, 2007 | 10:54 PM
goldwingman's Avatar
antennae does not go down, changed fuse in engine comp, no change, cell phoe is not on. Windows: If I get out of my car and hold down the unloc the windows fall. If I go inside and coe out a half hour later nothin, I changed batteries and I followed the reprogram steps sync key with car with no luck.
Is there a timer on how long you have to lower the glass on these hot days? BTW I tried this mornin to put key in and rotate all the way to unlock and hold for 4 secons it did not lower the glass either.
Thanks for your help in advance from a proff ff in md
