S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Power Antenna doesnt go up...Wheres best place to buy?
Old Jun 28, 2007 | 04:41 AM
chesee48's Avatar
Other then the dealer?
its a 1992 400SE...
Thanks!
Old Jun 30, 2007 | 03:18 PM
z168's Avatar
3phase-4pole
or you can find out whats wrong with the antenna first. does it make a grinding sound? if so, most probably a gear tab is broken (a very common problem). there is a repair kit you can buy that will replace all the gears and belts
Old Jul 3, 2007 | 05:02 PM
Mr. Benzito's Avatar
1992 300SE (w140) / 1997 E420 (w210)
I actually have one that I purchased, but have sold the vehicle since. If you would like to purchase it from me we could work something out!
I can send you pics as well... just PM me if you are interested. I had a 1992 300se so compatibility shouldn't be an issue.
Regards!
