S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
I have a problem with a 93 500sel
Old Sep 10, 2007 | 10:26 PM
orlando's Avatar
1993 mercedez benz 500sel
Smile I have a problem with a 93 500sel
I'm having a problem starting my car on . It all started by the engine skipping while running I checked under the hood and I notice that the engine wire harness was real bad. While the engine was running I made the mistake of touching the wire and the engine just shut down. I replaced the wire harness and it still won't start. I also check the sparkplug cables and there is no spark on none of them.I hope some one is familiar with this problem and may be able to help me.
Old Sep 11, 2007 | 02:53 AM
Vasir's Avatar
99' SL500, 16' i3, 14' Passat TDI SEL
you fried you computer? you need an inde shop, or dealer to check it out for you.
Old Sep 11, 2007 | 12:44 PM
waterman01's Avatar
s600/s420
Blown Fuses
You're computer is most likely fine, that is what the fuses are for!
Check your fuses, that is your problem.
Old Sep 11, 2007 | 05:53 PM
orlando's Avatar
Smile
thanks a lot waterman it was two fuses burn on the computer.I had a little bit of problem finding the fuses for the computer but i finaly found them and two were burn. I replace them and that was it. thanks a lot guys
