s320 length
What is the difference in a SWB and LWB?
Is all the room in the rear seat area?
any difference in car weight?
Is it noticable driving?
Which are there more of
I am looking to pick up a s320 95 to 99 range
any suggestions on pro or con year
thanks
hal
SWB means Short Wheel Base. LWB means Long Wheel Base. I wouldnt get a SWB if i were you. they look too goofy, and the legroom is not there for the back seat anymore.
Good luck on your car search!
LWB 5213mm, 17' 1.25", turning circle 41', height 1495mm (although the 600SEL is 1490mm)
Source: MB Technical data for passenger cars, October 1993 edition
The way I saw it is...if you're out to buy an executive class luxury sedan, like the S Class, 7 Series, etc etc, they were designed to offer as much space as possible for all occupants...why not go for the full size version? And I never noticed much difference in the way the LWB and SWB handle or drive. I mean it's only like 3 inches difference overall, and all of that is the wheelbase, in the rear area.
According to my 1999 S Class brochure, the S320 SWB weighs in at 4480, and the LWB is 4500 even. So there's not that much of a weight difference either.
I never drove an S420, just the two S320s and a '95 S500. IMO, the S320s have a little more than adequate power around town (lacking at lower rpms, and by lower I mean less than 2000), but the faster you go, the better they get. At speeds above 70-75, they are surprisingly quick considering they're only 228hp and 232 lb/ft of torque, pushing around 4500+ lbs. At speeds above 80, I'd be willing to bet they'd be neck and neck with a LT1 Powered B or D Body GM (Caprice, Roadmaster, Impala SS, Fleetwood). I've had my S320 up to 130 and she was still pulling!
From what I can remember about driving that '95 S500, it was downright fast. Not so much around town, but I can remember getting onto an onramp and punching it at about 30 and it pinning me into my seat, all the way up to 75! I've got a video of that, I'll post it later.
Hope this helps,
Chad.
