S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
shock absorber
Old Oct 29, 2002 | 11:45 AM
trope's Avatar
MB S600 1995
shock absorber
My shock absorber keeps on giving a "" knirk" sound when ever i drive over a bumpy thing on the road- do anyone have an explanation ?
Old Oct 30, 2002 | 11:16 AM
Stefano's Avatar
w140
Do you have the self leveling system?
Old Oct 31, 2002 | 03:38 PM
Stefano's Avatar
w140
Sounds Exactly like a Blown rear Shock Absorber. I had a jag that had the leveling system making the same sound. Fortunately I was able to buy a Kit that converted the Rear hydromaticshocks to be able to use the much less expensive every day shock absorbers. Not sure if such a kit exists for Mercedes. I know the The hydromaticshocks for the W140 are a bit pricey. I would recommend a second opinion. My current rear shock absorbers on my W140 are making the same sound, but this is the result of lowering my car considerably.. I will be replacing them with the heavy-duty Bilstien lowering shock absorbers. My W140 doesn’t have the Hydromatic system.
One other thing is to check, is that the bottom of the rear spring is seated correctly In place. This will cause the same noise but is unusual. Good luck
