S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Affect Of Tire Stagger On ABS
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 11, 2007 | 11:31 AM
blkopalS500's Avatar
1997 W140 Chassis S500 Sedan
Exclamation Affect Of Tire Stagger On ABS
I've got a '97 S500 sedan. I just bought a set of 19" rims with 235/35's all around as part of the package. It was immediately apparent that the car needed more meat in the rear. I picked up a hardly used set of Michelin Pilots, size 275/35's. This would give me a 4% difference in circumference front to rear. Before I put the 275's on my car, is the difference enough that it's going to screw with my ABS?
Old Oct 17, 2007 | 10:30 PM
snik's Avatar
96 S500 Coupe
the proper size for the front is 245/45/18 (that closely matches the stock size)
I have had 245/45/18 front, and 275/35/18 on the rear (rims off a w220 S55) on my previous s500 and it ran fine... No issues w/ ABS, although cruise stopped working
in my current coupe, I have 245/45/18s all around and since it's almost identical to the rolling diameter of stock, I have had no issues. Ideally, you should not be more than 3% off the factory spec.
use this link to determine the proper size:
http://www.1010tires.com/TireSizeCalculator.asp
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
