Afater-market stereo
Has anybody installed an after-market stereo with the stock amp? I just installed an Eclipse AVN on my 97 S600 and hear a lot of interference through my speakers. Do I need to bypass the amp or change it? Thanks.
2) Make sure you have a solid ground.
3) Are all your components the same ohm?
4) Double check your wiring that you didn't cross wires somewhere.
~Cali
~Cali
There are better amps, however 7 channel amps of better quality are very expensive. Stick with stock amplifier. Ohms are not a concern when you have power. 1 Ohm load is too much for most amplifiers, except Class A. Speakers Ohms is not a concern with any deck, since you are using the Main Amplifer for power, not the NEW preamp deck installed.
Any After Market deck is fine.
Cheers
