S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
One amp?
Old Oct 29, 2007 | 11:22 PM
qha000's Avatar
One amp?
Hi all,
I'm changing/bypassing my Bose amp and wanted to know if one 4 channel (6 channel) will be enough to power all doors and subs in the rear deck in my 97 S600. Any suggestions/recommendations as to which amp based on your experience? Thanks.
Old Nov 15, 2007 | 04:43 AM
skiendog's Avatar
'12 Cayenne Turbo, '12 GL450, '03 SL55, '89 560SL,
Originally Posted by qha000
Hi all,
the answers to the second part of that question as are numerous as the stars in the sky, buddy. to each his own with stereo equipment.
for the power of it, though, try to stick around stock power. especially with the electrical equipment in that S class. the alternator was built for a certain power, and mercedes did put thought process into the amperage of the battery. if your arent going to upgrade the speakers or put some bump in the trunk, just stick to the same rms output of the current one.
6 channel....i sure thought it was more like 10 you need.
