S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Rearview Mirror Rattles
Old Nov 16, 2007 | 12:02 PM
inline6benz's Avatar
2006 CLS500 1975 MB 240D 1995 Range Rover Classic 2000 ML55 AMG 2003 C32 AMG 2000 BMW M Roadster
When the car is staying around 80 mph the center mirror rattles is there a way to tighten it?
Old Nov 19, 2007 | 08:25 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
I know that a '96 has no way to be tightened.
Old Nov 19, 2007 | 11:33 AM
hinkel7's Avatar
1992 300 se mercedes
this is what i did
if you take the little plastic piece above the rear view off, be careful. it has a screw that has to be turned from an open face slightly angled wrench. if you just turn it a quarter of a turn it will stop that flopping from happening. this is sometimes very difficult as you cannot find the correct tool, and no slightly angled needle nose pliars do not work. if you are unsuccessful, place a small dab of a hi-quality superglue on the nut where it runs up the shaft so it will stop turning. this will fix it problably for a few years. good luck don't break it.
