S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992- 400SE is a...??
Old Nov 21, 2007 | 08:36 PM
HighRoller's Avatar
E320-SL-300, Stang5.0-Volvo242 and some more
Exclamation 1992- 400SE is a...??
A 400SE from 1992 is a good car? This one have 208,000 milles on it.?That is a lot of milles or is ok? The car is only $2,500.body is ok, interiors is average,the car need a tune up,is making noise in the front suspencion,and the mechanic mention something like evaporator cuz leak the a/c gas in a week.Engine and trany is good. What you guys have to say ???Thanks in advance.
Old Nov 22, 2007 | 12:12 AM
NZ_Benz's Avatar
1993 300SEL/S320
AC core will cost between 3-4K to replace so along with those other problems it's not worth it.
Old Nov 22, 2007 | 04:59 PM
HighRoller's Avatar
Old Nov 26, 2007 | 09:37 PM
HighRoller's Avatar
Anybody else!!
Old Dec 19, 2007 | 08:41 PM
miroxz's Avatar
i would pass on it. evap. alone will cost you 3k, also 92-95 had degradable wiring harnesses=$1k...running away while you can=priceless
Old Dec 20, 2007 | 04:50 PM
BENZBAEZ's Avatar
Anything I can afford
That millage is ready to do the timing chain and rails. Oil pressure might be low because of poor oil circulation. Oil sludge on cylinder heads. Might need new oil pump too. If you can do all the work buy it. If you have to send to the shop to do engine or a/c work don't buy. look for something with less miles less years.
