S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Help!, Cant switch Blower off!!
Old Dec 13, 2007 | 01:02 PM
Callum's Avatar
1992 500SE
Help,
After reading the excellently documented Blower regulator replacement guide, i went ahead and replaced my inoperative Blower regulator.
Brilliant i thought as the blower sprang into life far more powerfull than at any time before!!
Problem now is i cannot adjust the blower speed, it stays at full throttle no matter where the min max wheel is set to.
I have just had to disconnect the battery, as the Blower is running even with the car switched off and draining the battery.
Anybody help on this, is there a relay somewhere i can check, surely the brand new regulator cant be faulty?!
I am pulling my hair out over this, as it's now winter in Scotland, and i could do without getting under the bonnet every day.
Thanks in advance
Callum
