S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Transmission Fluid
Old Dec 26, 2007 | 04:56 PM
adsacu's Avatar
1992 300se
Transmission Fluid
I am a new owner of a 1992 s320 with 135k. What is the recommended trans fluid?
Old Dec 27, 2007 | 05:05 PM
tirona's Avatar
1997 s320, 1997 e320
you have a 300se (3.2L), there wasn't any s320 until 94. you have a 722.5 transmission, so you need to buy a 722.5 at filter/pan gasket kit. you can use Dexron III in it, and it doesn't have to be synthetic. i would get mobil dexIII tranny fluid. also your torque converter has a drain plug, so you can get almost all of old fluid out. since your car is 16 years old, if the fluid has never been changed, i would change it, drive it for a week or so, and then drain it and change the fluid/filter again, since the new fluid will loosen some buildup in it and you don't want that in there.
Old Jan 1, 2008 | 07:05 PM
adsacu's Avatar
1992 300se
This is my sons car it is actually a 94 s320
