S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
rear window shade s500
Old Mar 12, 2008 | 11:00 PM
stevie-b's Avatar
i put the rear window shade up,now it wont go down and the rear headrests will not work. any suggestion or advice would be appreciated. thanks
Old Mar 20, 2008 | 11:52 AM
assman300's Avatar
1999 s500
hello, since they both stopped working at the same time,, it would make me think that maybe a fuse that controls those went out..... i would check the fuses first.
mike..
Old Apr 8, 2008 | 09:25 AM
haku's Avatar
~ 1996 S320 ~
If that's not the case then, as far as the sunshade is concerned - if you can still here the motor making a noise when you hit the switch it's most likely seized. It's quite a process getting these apart and re-oiling them. Mine's currently in the 'seized' state waiting for some work.
