S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1995 S320 fuel leak
Old Mar 16, 2008 | 07:05 PM
fdixon001's Avatar
1995 S320, 1990 300SL 1984 380SL
1995 S320 fuel leak
I have a fuel leak coming from under the car about midway. Are there any fuel lines in that area, or could it be traveling from another point and accumulating in one spot on the ground?
F. E.
Old Mar 17, 2008 | 09:51 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
The fuel lines run along the drivers side back to the tank. Just in front of the rear wheel is the fuel filter. The filter is attached to the lines with rubber line that can get old and leak. That is where I would look first. Obviously this would be a good time to change the filter.
