S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
94 s320's rpm goes up and down when hot
Old Jun 10, 2008 | 11:15 AM
my_galaxy's Avatar
94 mercedes s320
hi guys
i have a 94 s320, when i start in the morning it starts fine but when i drive around and stop on the light or just put it in the parking, engine's rpm start going up and down and sometimes it shuts down. but if i keep my foot on the accelerator just little bit then rpm stays normal.
can anyone help please?
thanks
Old Jun 12, 2008 | 01:59 AM
OdinsThrone's Avatar
1998 S500
I have a 98 S500 that does the same thing but it does not die. Mine jumps from idle 700 rpms to about 800 back to idle.
Old Jun 12, 2008 | 09:34 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
I had the same problem with mine a couple of years ago. It ended up being the fuel regulator. This is a fairly inexpensive part ( about $90)and easy to fix – about 15 minutes. It is located on the right top front of engine. One way you can tell if it’s going bad is to pull the Vacuum line off and smell it. If you see or smell gas it’s bad. The diaphragm starts letting gas seep by. Hope this helps
