S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
600 SEL coolant problem help needed!
Old Jul 23, 2008 | 02:31 PM
spierce88's Avatar
S600L
hey everyone,
all of the sudden when i was idling in a driveway the coolant started puring out of the drain at the base of the engine block. At first I though it was a rad hose, or that crazy T shaped plastic part against the firewall everyone has problems with, but ive sourced the leak from the drain hole for the overflow trough at the base of the engine block. when coolant is poured into the system it pours right out of the drain hole! any ideas as to what the problem is? please help if you have a suggestion. thanks!
