S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Does the D.V.T. Adj Rod Nut go under or over the Adj Rod plate?
Old Sep 17, 2008 | 03:50 PM
azdbroker's Avatar
2013 E350 Sport 4Matic
After R&R the Drive Belt Tensioner Adj. Rod does the bottom flat part of the nut go on the top or under the Adj Rod plate?
1995 S320 3.2L, engine # 12-13800+
Should be a mechanical tensioner I know... but it is the non-mechanical hydraulic. Don't know why.
Thank you in advance!
