S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Instrument Lighting
Old Jan 2, 2003 | 08:50 PM
///S320's Avatar
S320W
Angry Instrument Lighting
Does anyone know how to change the light behind my dash clock? It really bugs me, when i dont see a light anywhere inside the dashboard..
Also, the right arm rest in the front has this sliding tray type of thing made up of some sort of paper (the one you can slide and put coins and cds etc under the arm rest) is jamed. I dont know how to open it, it only opens less than half way, looks like its struck somewhere.. has anyone ever had this problem??
///S320
Old Jan 7, 2003 | 07:32 PM
wmak8's Avatar
In order to change the light bulb behind the clock, you have to pull out your instrument cluster. Unless you have the dash tool to pull out the cluster, you are probably better off bringing it to someone who does. Or you can try pulling it out by hand. That's what I did. You have to have lots of patience and be prepared for some sore fingers Let me know if you need more info.
