S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
non-stop buzzing!
Old Nov 16, 2008 | 11:08 PM
mpsport's Avatar
s420
non-stop buzzing!
hi everyone, My car has been buzzing all week and I can't find out the problem. My car is 95 S420, the buzzer just don't stop after the car has started. non of the dash warning light is on. Can I unplug the buzzer or what do you think the problem will be? I'm start to dreaming about the buzzer at night now!!! Thank you
Old Nov 17, 2008 | 05:21 PM
Wisegy123's Avatar
1995 S420
Where Is It ?
Where in the car is the "buzzing" coming from ?
Old Nov 18, 2008 | 01:04 AM
mpsport's Avatar
s420
is the same buzzer sound as when you first put your key in the ignition. and the sound is coming from under dash area by the key ignition.
Old Nov 19, 2008 | 02:20 AM
mpsport's Avatar
s420
Problem Solved!
problem solved! I should of check all my fuses before I ask any questions. Fuse 24 under the hood was bad. thank you
