S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Radio ISSUES
Old Dec 13, 2008 | 02:24 PM
cpr_metro's Avatar
Radio ISSUES
Hi All
Have a 1998 CL500 Coupe
Have been having an issue where I am listening to the radio and then it
will display "PHONE". This happens intermittently.
The car does not have a phone installed and as far as I know never did.
Ideas ??
Old Dec 25, 2008 | 11:27 PM
Runninrebel211's Avatar
1993 190E 2.6
Sounds like some wires are loose. Check your trunk - the left side quarter panel should have a box there that says telephone communications if you have something connected at the marked PHONE slot then you do. Check for a leak there too. Sometimes when water drips on it, it will cause intermittent problems.
