S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
How do i know its the PSE pump and NOT loose hose??
Old Dec 28, 2008 | 06:59 PM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
Ok, these are the exact problems I have.
1. The door locks will not work at all
2. The Headrest button will NOT work at all
3. The Trunk AJAR button will NOT work
But, whenever I press any of those buttons, I hear the PSE pump working
However,
The door and trunk suction both work.
Also, if I lock the car(the door) and I unlock, it will NOT re-open. Sometimes I need to disconnect the battery, sometimes fuses.
Any ideas??
Old Dec 31, 2008 | 08:24 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
There are two pumps in the car, one to draw in the doors and trunk lid, it resides in the trunk above the rear wheel. The other is under the pasenger rear seat, it provides pressure and vacuum depending on the direction it is running, The doors, gas lid and trunk lock are provided pressure to unlock vaccum to lock. The pump provides pressure for the lumbars via a eservoir, and supplemental vacuum for the HVAC thru another reservoir when the engine is not producing any. The back up rods (if you got them) trunk handle and headrest release ( if you dont have electric) are also served. The pump has safeties for pressure, time depending on the circuit, 10 seconds in lock circuit 60 seconds for lumbars and HVAC.
Be carefull pulling off hoses, if you break a nipple you are screwed. In the mid 90s there were some defective pumps with a bad internal hose, MB had some so you could replace them, I doubt any counter guys will recall. There are really no replacement parts, altho rebuilts are available.
There are also two styles one with a plenum that terminates the hoses the other is made up out of "t"s and splitters and caps
Old Nov 11, 2012 | 08:41 PM
bluemax450slc's Avatar
1995 S-320
shadetree mechanic
Where are such rebuilds available, please, for my 95 S-320 LWB?
Old Nov 12, 2012 | 01:33 AM
johnny conkaroo's Avatar
97 s420
idk if this helps. i need a pse pump. my doors, gas tank and trunk dont work electrically. my head rest button does work tho. you can find a used pse pump online for about 130 bucks but i have seen like 4 different pumps supposedly for the w140s
Old Nov 12, 2012 | 01:34 AM
97 s420
o yea the soft close works too
Old Nov 13, 2012 | 06:02 AM
eddie a's Avatar
94 S420,95 S500 ,96 S500
Part numbers must be exact although, there are some that are interchangable...google it and research it
