A/C Pressure help
A/C Pressure help
Need to find out what the pressure should be on the low and the high side on my Benz. We emptied the system yesterday and filled it. However it is not blowing supercold, just cool. No leaks and the compressor is working fine. When looking in the book for the correct pressure it stated not available. I have a -95 S420.
Thanks!!
Thanks!!
Former Vendor of MBWorld
Mercedes
Thanks!!
Thanks!!
Mercedes does give the refrigerant pressure to turn the fans on and off.
things with and without wheels
Is it possible that you have moisture in the system?
Look at the temperature /pressure conversion chart, if pressure is 10% above, then it might be contaminated.
Ambient temperature plays a big part in low and high pressure readings.
post your pressure readings along with the ambient temp.
