S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
s55 or s600
Old Feb 1, 2003 | 07:38 PM
ano0oj's Avatar
09' 335i coupe
s55 or s600
thinking what would be a better buy...
if anyone could help thanks a lot
Old Feb 1, 2003 | 07:51 PM
jswedberg's Avatar
C32 AMG
I believe this has been worked over in prior threads - you should do a search.
Briefly, it depends if you want a sporty large car or a cushy large car. The have about the same power - the S55 has a little less torque but is lighter weight.
The S600 has some extra wood and leather and what-not you can't get on any other S.
I believe the S55 is a little cheaper - but if you can afford $110K then a few thou up or down shouldn't matter - get what you want!
Old Feb 1, 2003 | 07:57 PM
ano0oj's Avatar
09' 335i coupe
thanks
Old Feb 1, 2003 | 09:32 PM
vraa's Avatar
I remember someone did a test with the older engined ones, does anyone have a test with the newer engines?
