Limp take off
Vic.
Have you verified that you are starting off in low gear? Every once in a great while my s600 will get into a mode where it remains in a higher gear. It does not fix itself as long as the car is running. Manully shifting into low does not change it. My fix is simply restarting the car. It must reset the computer and then it is fixed.
Just a thought.
Jim
Vic.
I would keep your suggestion in mind. A trained tech said that it maybe a bad air flow meter which I would try first since I have access to one. You may be right because I was never happy with the tranny.
Vic.
