S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
AC / Heater blower not working 97 S420
Old Jun 25, 2009 | 11:01 AM
mmi1's Avatar
1997 S420`
97 S420 The control unit works and i can turn on the ac or heat and if i put my hand up to the air discharge area you can feel the temperature change but the air will not flow. It does not matter if I turn the fan up or down nothing happens. I checked all the fuses in the fuse boxes and they are fine. Any help would be greatly appreciated... Thank you
Old Jun 26, 2009 | 08:20 PM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
replace relay located on the engine compartment where the charcoal filter is located, you need to take out the plastic cover with a philips screw, its on top of the blower motor.
Old Jun 29, 2009 | 10:15 PM
TMAllison's Avatar
09' E320
Test the blower motor first; if it works consider the regulator. Common failure.
