S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Overheating problem 1991 Mercedes 350 SDL
Old Feb 22, 2003 | 08:44 AM
drapp's Avatar
1991 350SDL
Doe's any body know what could be the overheating problem? I took the car to mechanic because the Heat wasn't working. First they changed the thermostat, that didn’t do it. Than they put a new radiator, cause the old one was clogged. It still doesn’t work. the engine builds a lot of pressure and overheating.
Old Feb 23, 2003 | 03:44 PM
rdanz's Avatar
Head Gasket
Old Feb 23, 2003 | 03:46 PM
rdanz's Avatar
Head Gasket, water pump could be a number of things I would find a better mechanic
