S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
after market stereo installation in s320
Old Oct 8, 2009 | 06:52 PM
my_galaxy's Avatar
94 mercedes s320
guys i been installing aftermarket stereo into my s320. everything worked out except i couldnt get any sound into the speakers. what am i doing wrong. i d appreciate the help if someone have installed the system in w140
thanks
Old Oct 9, 2009 | 02:14 AM
Z06EATER's Avatar
1997 C36AMG
no sound? did you bypass the stock amp?? u need to bypass it...
simply pull of your running panels under the doors and run wires from the deck to the wires that are under the running panels, those wires run to the speakers in the rear doors. front speakers should be the easiest once done u will get sound.
i installed a navi unit in my C36 all by myself. and JL tweeters and a W6 it sounds awesome!
Old Oct 9, 2009 | 09:50 AM
my_galaxy's Avatar
94 mercedes s320
thanks
thanks for your reply. i was wondering isnt it the same concept as other amps. that when you put the live wire and remote wire amps turn on. i am just wondering am i missing any 12v wire that goes to the amp?
i wanted to use that bose amp even though it doesnt give me the sound properly.
jag
Old Oct 9, 2009 | 10:10 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
From what I have heard the output of the Becker was not standard audio, people have done it by using adapters. The Becker 92-95 was a two piece radio and had two channels feeding a seven channel amp. Here is the plug from the bose amp
Bose Amp Connector Pin Designation: (See attach. for Plug Pin Desig.)
From All Data
1 Circuit 30, F4-16
2 Ground (W6)
3 Right Rear Speaker (H4/8)(-)
4 Left Rear Speaker (H4/7)(-)
5 Right Rear Door Speaker (H4/4)(-)
6 Left Rear Door Speaker (H4/3)(-)
7 Right Front Door Speaker Group (H4/2)(-)
8 Left Front Door Speaker Group (H4/1)(-)
9 Right NF Signal (+) from A2/3
10 Circuit 30, F4-16
11 Ground (W6)
12 Right Rear Speaker (H4/8)(+)
13 Left Rear Speaker (H4/7)(+)
14 Right Rear Door Speaker (H4/4)(+)
15 Left Rear Door Speaker (H4/3)(+)
16 Right Front Door Speaker Group (H4/2)(+)
17 Left Front Door Speaker Group (H4/1)(+)
18 Left NF Signal (-) from A2/3
19 Control Voltage from A2/3
20 Fader Switch (R26) (-)
21 Fader Switch (R26) (+)
22 Fader Switch (R26)
23 –
24 Right NF Signal (-) from A2/3
25 Center Fill Tweeter (H4/11) (-)
26 Center Fill Tweeter (H4/11) (+)
27 Left NF Signal (+) from A2/3
R26=Fader Switch
A2/3=Tuner Amplifier
F4-16=Fuse Box Trunk, Fuse 16
Old Oct 11, 2009 | 09:28 PM
my_galaxy's Avatar
94 mercedes s320
finally installed the off market stereo
thanks peter
FINALLY I INSTALLED THE STEREO, EVERYTHING WORKS. it was very easy. Antenna power and speakers + wires turns on the amp. thats what i was doing wrong.
thanks again
