Gas leak 1994 s500
How do you fix a leaking gas issue on 1994 S500? It happens only when you start teh engine and has a constant drip that appears to be on the line after gas tank? Can this be repaired by a do-it-yourselfer?
It's the return hose, coming from the fuel filter to a line that's, on the bottom on the gas tank... Mb dealer has to order it, it will take two weeks
from over seas...To long for me, I went to a place in houston and pick up
the hose off a S500...same hose..
Not sure if you have had this fix...
I see it's an old post...
Well, good luck...
