S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
95 s500 possible tps problem
Old Feb 1, 2010 | 03:12 PM
shegel's Avatar
2004 E500
My car was hesitating. I called the dealer, they told me to replace the kickdown switch which i did. then fuel filter, then fuel pump. still having the same problem, they then advised me to rebuild my throttle body. I just finished that and I am still having the same problem.
thanks in advance,
Steve
Old Feb 1, 2010 | 06:56 PM
TMAllison's Avatar
09' E320
Have you read the OBDi blink codes from under the hood?
Old Feb 2, 2010 | 04:37 PM
shegel's Avatar
2004 E500
I'm not as familiar with OBDI, where is it located, where is the reference to read the codes.
Old Feb 3, 2010 | 05:28 PM
TMAllison's Avatar
09' E320
Usually adjacent to the fuse box under the hood. Round 16 pin with screw off top. You'll have to use search for what the blinks mean.
