S500 Wiper Arm Issue
Hi.
The passenger side wiper arm on my S500 got stuck in up position and did not move. I checked the nut holding on the arm and it was a bit lose so tightened it up...wiper starting moving for about 10 cycles and then stopped again.
Checked and the motor and it is turning fine. Seems like the arm and mount are stripped (no grip) on the arm. My question is, do I need to replace the arm? Any suggestions?
Thanks.
Benz14.
Thanks.
Benz14.
1998 and 2002 SL 500, 2014 E550 Convertible
Hi.
Thanks.
Benz14.
Thanks.
Benz14.
http://www.odometergears.com/subpages/mb.html
Thanks for your reply! The shaft is rotating..I tighten the nut that holds the arm on and the wiper will move correctly for about 10 cycles then it just stops moving, but the motor(shaft) continues to move...not sure it would be the gears as you mentioned?? If the shaft splines are stripped, does that mean a replacement of the motor or can I just replace that piece...thanks for any help...just want to be armed with as much info as possible before making the plunge to have it repaired...
benz14
benz14
benz14
benz14
