S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Changing Rotors on 95 S 420
Old Mar 30, 2003 | 09:37 PM
Chuckg's Avatar
1995 S 420
Can any tell me how to change rotors on an 1995 S 420?
Old Mar 30, 2003 | 11:04 PM
Dr Chill's Avatar
Porcelain Bus
Not too hard
First, after removing the wheel, you have to unbolt the calipers and let them rest on a cinder block or jack stand rather than dangle from the brake line. Next, there is a single Allen bolt near the holes in the rotor where the lug nuts thread that needs to be removed. Some liquid wrench may be needed to free it up. Then take a heavy mallet or hammer and pound on the inside of the rotor until it frees up. Slide the new rotor back on, replace the Allen bolt and then reinstall the caliper. You may need to squeeze the piston back a little on the caliper since the new rotor is thicker than the old one. I recommend Balo rotors since they are the same ones that came originally with the car most likely. Good luck.
