S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
CD Changer questions
Old Apr 7, 2003 | 05:52 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
I just purchased a 1993 300SE and would like to add a CD changer, however I do not want to pay the dealer $1000 to do so. Does anybody have any suggestions for compatible CD changers or where I can get one of the ourginal (10 disc?) CD changers for this car?
Old Apr 7, 2003 | 06:17 PM
Snowman's Avatar
Re: CD Changer questions
The original 10 disc CD changer was a Becker 980 that is no longer made.
However it is possible to use an Alpine cmh-s630 cd changer and a translator so the cable pre-wired in the car can already connect to the changer.
Now here is info regarding the translator, I am not entirely sure on all of it:
Q-6-82-0135 -- software interface $135;
Q-6-82-0174 -- adapter harness $50;
Q-6-82-0175 -- cable set $98;
Alpine CHMS630 CD Changer
Peripheral adapter MBZALP9 $37
Those would be all the things you need for it. The first 3 are available from parts shop at mercedessop.com. The CD changer can be had from http://www.proactiveelectronics.com/AKCHMS630
and the peripheral adapter from http://www.autosoundgear.com/
Old Apr 8, 2003 | 10:13 AM
MPM77's Avatar
Regarding the Alpine model you suggested, CHM-S630, Alpine also offers an upgraded model, CHM-S634. Do you know if the s634 is compatible? The only differences are the ability to play MP3s and display the CD title. I really don't care about the CD title, but playing MP3s would be a great addition?
Also, if you do a search on google.com (i.e. just type "Alpine CHM S630") you will find it much cheaper than the link in the prior post.
Thanks in advance for your reply to my question!
Old Apr 8, 2003 | 10:27 AM
Snowman's Avatar
I got the info from SCJLA at mercedesshop.com. He's a member over there in the audio forum. It's possible that it might work, but then again it might not. To be sure you could go over and post in the original thread. Search for W140 changer.
Old Apr 9, 2003 | 10:04 AM
MPM77's Avatar
Happy to report that SCJLA responed to my question at mercedeshop and his answer is yes. The CHM S634 is compatible to the OEM head unit.
Old Apr 9, 2003 | 10:11 AM
300SE1993's Avatar
Does this mean if I buy that unit, that I do not need all those adapters?
Old Apr 9, 2003 | 10:21 AM
MPM77's Avatar
According to SCJLA, if I am reading it correctly, you need to buy two additional adapters.
See the thread
http://www.mercedesshop.com/shopforu...highlight=w140
Old Apr 20, 2003 | 05:48 PM
300SE1993's Avatar
I found the perfect solution. I bought a CD player for $26 at Wal Mart and used my cassette adapter, and surprisingly it sounds good. problem solved.
Old Apr 21, 2003 | 02:32 AM
Snowman's Avatar
Yes that is probably the cheapest alternative.
Old Aug 15, 2003 | 01:48 AM
Bernanke's Avatar
i am curious as well I also have a 1993 300SE and i did portable CD player but its kinda ghetto looking to have that setup in such a nice benz.
I want a 6 disc MP3 CD changer, any suggestions?
Old Aug 15, 2003 | 08:01 AM
MPM77's Avatar
The Alpine S634 plays MP3's, CD's and most importatant, it works seemlessly through your stock headunit according to SCJLA.
Old Aug 15, 2003 | 08:22 PM
Bernanke's Avatar
ya thats the one I want, but one important question, will it say the folder names of song names (ID tags) of the Mp3's and etc? if so that would be perfect, if no thats still ok. thanks !
Old Aug 15, 2003 | 09:38 PM
zindallas's Avatar
1998 cl 600
The changer certainly supports all the data tags, but unlikely the OEM head unit can handle it.
I swapped my entire stock system for Alpine (7998 head unit, S634 changer, F450 amp, new speakers all around - 3-way components in front and 12" sub in trunk) and am very happy with it. Much better than stock in my opinion.
Gotta have quality tunes to match a quality car!
Cheers!
Z
Old Aug 16, 2003 | 01:33 AM
Bernanke's Avatar
wow that sounds like alot of work. I just want MP3 CD player/changer. is there anyways to install a LCD screen seperate that would display ID tag dad and etc? i have the empty Phone slot so i could put the LCD screen there and it would be a very nice addition. what yall think?
Old Aug 16, 2003 | 06:14 AM
ghost's Avatar
1997 S600 - Bentley Turbo R (black/black)
i am also interested in finding out if an LCD screen would fit fine in the empty phone area in front center dash?
Old Dec 19, 2003 | 05:47 AM
Bernanke's Avatar
hey guys, I am reviving this thread b/c i really want a cd changer 6 or 10 disc that will work with stock system. all the mercedes changers i see are only 94+ compatible and I have 93 300SE. anyone have ANY idea what i can do. PLEASE help
