S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992 Mercedes Benz 400SE Bogs Down
Old Aug 6, 2010 | 03:16 PM
frostbite's Avatar
1997 Mercedes Benz S500
I have a 92' 400SE and when you start it and first push the gas it bogs down for the first few seconds. Then after a few seconds it takes of just like it should. I was thinking maybe it was a Catallitic Converter or Crank Positioning Sensor. Does anyone have any idead I could really use some help. Thanks.
Old Aug 11, 2010 | 11:29 AM
deanyel's Avatar
400E
You should build the code reader and read the fault codes on the 38 pin connector in the engine compartment, in the black box where the battery would normally be.
