S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Weird climate control issue
Old Apr 21, 2003 | 08:01 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
The climate control on the passenger side of my car adjusts the temp and location of the air just fine.... unless heat is required. It does everything it is supposed to but actually blowing hot air. What do you guys think could be the problem?
Old Apr 21, 2003 | 09:32 PM
EdS320's Avatar
S320
Sounds like a vacuum flap not operating, opening or closing. Common problem. Try the A/C system self test and see "Chart 2" to see what flap is not working. See link below for A/C system self test procedures. Some flap diaphragms are easy to replace some are hard.
http://www.continentalimports.com/ser_ic40142.html
Old Apr 22, 2003 | 12:54 PM
300SE1993's Avatar
Thanks for that info, but either I am not doing something right or the '93 model is different. I could only manage to get like 4 different temperature readings and a few other numbers when I attempted to do the flap test. Is there a different procedure for the "93 style?
Old Apr 22, 2003 | 01:30 PM
EdS320's Avatar
S320
Sorry I didn't see your year, 1993. The flap test may only work for 1995 and up? Double check doing the test to make sure you are not missing somthing. It worked on my 1996. Call your local MB dealer and ask if the test works on 1993.
