S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Radio Code
Old Oct 15, 2010 | 02:01 PM
rstraats's Avatar
S320 Mercedes
Radio Code
Prior to disconnecting the battery, is there any way to retrieve the radio code if you don't have the card or owners manual from previous owner?
Old Oct 15, 2010 | 06:28 PM
benica's Avatar
1998 and 2002 SL 500, 2014 E550 Convertible
Not really...unless someone wrote the radio code on top of the radio housing in which event you have to pull the radio to verify.
Go to the dealer...for free...they will get you the code.....usually past work orders from dealers have the radio code on the work order.
If you are not the original owner...the dealer will still have a record...they need the VIN, etc.
If you have a 1432 radio...it's a 4 digit code...
Old Oct 16, 2010 | 02:07 PM
rstraats's Avatar
S320 Mercedes
OK, Thanks! I'll try the dealership and see if they can give it to me.
Old Oct 16, 2010 | 02:11 PM
raymond g-'s Avatar
99 E320
https://mbworld.org/forums/e-class-w...adio-code.html
