S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Windshield Fluid Leaking
Old Apr 27, 2003 | 10:26 PM
ychachad's Avatar
1995 S420
IS there a simple fix to this? can the tank be removed and glued with silicone? How hard is it to remove and find the leak on the windshield fluid reservoir? Thanks in advance.
Old Apr 30, 2003 | 08:29 PM
billymueller's Avatar
1994 s320
I thought had a leaking washer res but after pulling off the bumper and taking a good look I found that it was the washer pump itself that was leaking. Before removing the tank make sure it is not the pump, gromments or filler neck that is the source of your leak. Good luck with your project.
