97 s500 heater problems
S420
hello everybody , i bought a 1997 s500 today and need some help with the heater. a/c on works perfect, but when you turn the heater on nothing blows threw. the center buttons up top dont even light up the hot/cold switch between the vents , what should i look for does anyone know .... please help
S420
OK THIS IS WHATS GOING ON , I CHECKED IT AGAIN BASICALLY WHEN ITS ON A/C THE CENTER VENTS BLOW COLD AIR AND THE SIDE ONES BLOW WARM AIR. THEN WHEN I SWITCH IT TO HEATER NO MATTER WHAT SETTING ITS ON THE CONTROL PANEL THE DEFROSTER SECTION IS WORKING NOTING FROM THE CENTER VENTS , SIDE VENTS BLOW LITTLE HOT AIR AND THE FOOT AREA BLOW STRONG , AND THIS IS ON FULL BLAST, ALSO THE CENTER VENTS HAS 2 SWITCHES RIGHT , IT DOESNT TURN ON AT ALL I CANT SWITCH IT TO HOT OR COLD. , IS THIS GOOD INFO YOUR YOU TO KNOW FOR SURE WHATS GOING ON? THANX FOR ALL THE INFO YOUR GIVING ME
