S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
What to look for
Old Dec 29, 2010 | 10:22 AM
walnutgroveplay's Avatar
1997 s320
What to look for
Will be picking up just purchased 1997 MB s 320 this pm. Has 74,071 miles with dealer records in glove box. Called MB dealer service manager that performed all service from day one, looked up VIN. He said no reason to bring vehicle in-previous owner was redundant about service. Stated he knew car and it was in excellent condition.
In reviewing records the following items were replaced:
8,032 miles Oxygen sensor
17,500 Instrument Cluster
20,723 Cylinder Head
31,000 Driveshaft flex discs and drive belts.
What should I expect next? Is it worth $2000-2500 to purchase extended warranty?
I have reviewed this site many time while making purchase decision. You all have been a great help. Thanks
Old Dec 29, 2010 | 04:45 PM
MB_Fahrer's Avatar
Deleted
Do an oil change and all fluids flush. Find out when the tranny fluid was changed last as well. If I were you, I would only use Mobil 1 0w40 Euro Blend oil. You can find my oil post in the off topic section of this forum. A very good case has been made about why to use that oil in particular. Crawl under the front of the car (behind front wheels its very easy) with a flashlight and check the shocks for any leaks. If they are leaking its time to change them. Also find out when the spark plugs were changed last. Is there any whining noise when car is running? Could need a new belt/water pump. Congrats on the purchase!! Post up some pix when you get it! Hope you enjoy it!!
Ricky
As for the warranty, I would say its up to you. Sometimes these cars need no work, but other times these 140s can be a real pain in the a**. Its merely "the luck of the draw" as Haku stated. He has a 600 and a 320. His 600 never needs any work but his 320 is always having something done. I recently picked up a 1992 600sel and the thing is a complete headache (as are ALL of my mothers W140s). They are in the shop at least once every other week for something (usually not always $$$ but sometimes whatever breaks is $$$). So if budget is an issue I would suggest the warranty. What are the details on the warranty?
Old Dec 29, 2010 | 09:53 PM
1997 s320
Thanks for the advice, will post pictures as soon as I figure out the process.
Old Jan 5, 2011 | 10:39 PM
ramblinche81's Avatar
1994 S420
Warranty has Heavy Restrictions
I asked the same question as you and was provided some insight to the details of most if not all extended warranty / service plans.
There is a total payout cap, typically in the $10,000 to $12,000 range which sounds reasonable....but
Max Paid on Electrical could be as low as $600
Max Paid on AC could be as low as $1000
Max Paid on Transmission as low as $2500
Max Paid on Engine as low as $4000
various other component categories, $500 to $1500.
Things NOT covered..which are likely to be a problem...
Wiring Harness is famously bad in these cars
Rotor, Distributor Cap,
Radiator
Head Gaskets
Mass Flow Sensors anywhere, intake , fuel, exhaust
It just seemed to me the only way the program was worth it was if I had multiple component failures and based on discussion with a couple mechanics, that is not likely.
