S500 Cd-rom Repair Manual
94 S500 Coupe
Anyone know if CD-ROM Repair Manuals are available for my 94 S 500 Coupe. I'm a Technician at a Bentley Dealership and I find it very difficult to find any literature on these cars and I'm not about send the car to a MB dealership when I could fix the car my self.Any info would be greatley appreciated. Thanks......
I subscribe to .www ALLDATA.com DYI for $24.95 yr {1st yr. $14.94 each Yr. after} for my 1996 S320. It is a "Full" online up-to-date service manual and tech info. Info. provided by MB to AllData, the same info. that independent shops use and subscribe to. I have CD's I bought online also {most are burned copies} and they are usually not up-to-date and only cover a small amount of repair info. and not in detail. Go the site and click on DYI and see if your car is listed. It's a great service for the Do-it-yourself'er.
94 S500 Coupe
Thanks eds320. We have the ALLDATA account at work but I coudn't find the problem I'm having with my car listed on it. May be you might know. The turn signals are staying on with the car running. Left or right it doesn't matter. The switch is cancelling from left to right though. I can only guess its the combination relay but I'm not sure.....
I bought a cd service manual from a guy on eBay for a '92 500sel. He had a bunch of them for all years. But he is no longer selling on eBay though. I can look on mine to see of it has what you are looking for. But keep in mind that this is for a '92 sedan. The files are in pdf format and should be easy to email. I will look tonight
You might try opening on your alldata "electrical" and see "Lighting & Horn" for wiring digram for the turn signals. It could be the "Flasher" has failed, burned a short, check it. Good Luck.
