S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
coolant leak issue
Old Apr 16, 2011 | 11:12 PM
vdubpower's Avatar
i drive them all, fast and hard
coolant leak issue
so ive noticed coolant leakage at the reservoiur tank, not at any of the hoses or at the radiator
the cap looks good and seems to be on tight, but after the car is shut off, it sseeems to pour out quite a bit from the cap area
we refilled it with peak green coolant/antifreeze...hope it was the right one
anyways, what could be the issue
the engine temp is fine, 80 c
Old Apr 18, 2011 | 01:03 PM
oldsinner111's Avatar
s320
Sound like pressure in coolant due to bad head gasket.Ma Benz used crappy head gaskets on their gas engines.
Old Apr 18, 2011 | 04:52 PM
vdubpower's Avatar
u dont think it might just be the cap?
Old Apr 30, 2011 | 04:21 AM
cnrail's Avatar
W140 S320
I would check the reservoir itself - particularly where the hose to radiator connects. Mine had a small crack in it and would require a top up every couple of weeks. replaced for about $100.
