S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
problem removing valve cover 92 500 sel
Old Jul 6, 2011 | 11:06 AM
stejay's Avatar
380 sec, 380 sl, 560 sec, 500 sel
I am having trouble removing the valve cover from my 92 500 sel. I have removed the bolts but it won't budge. Is there a special tool or trick to get this thing off?
Old Jul 6, 2011 | 01:12 PM
oldsinner111's Avatar
s320
If its like the m104,does the spark plugs go thru center of rocker cover?
Old Jul 6, 2011 | 09:00 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Yes plug wires go through cover... but if your sure you have all the bolts off your going to have to pry with a pry bar or screw driver... if you run a puddy knife around the gasket it will break easier...
