S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
96 S600
Old Aug 4, 2011 | 11:13 PM
S600 W140's Avatar
96 S600 W140
96 S600
i want to put some kind of flowmaster on my w140 96 s600...does anyone know what kind or size exhaust i should do to make it sound nice, but not like a truck.....also i want to put some 20" staggered wheels on it..any suggestions?
Old Aug 5, 2011 | 09:25 AM
oldsinner111's Avatar
s320
You will have to use a tape measurer or caliper (better) to measure diameter of pipe.I found that removing center mufflers produces a richer note.I don't know if your single exhaust,but duals would be so much better.I like the flowmaster 40 series muffler.As for wheels try tirerack,and click tires for your car,optional sizes and rear larger.larger wheel in rear is good for drag racing.But if you want to use your muscle anywhere,same sizes all around.
Old Aug 11, 2011 | 12:47 AM
S600 W140's Avatar
96 S600 W140
should i just put the flowmaster 40..or what size piping..2.5" or 3"? i just want my car to look nice with staggered wheels but dont know which kind?
Old Oct 4, 2011 | 07:28 PM
michobebe's Avatar
W220 S500 2003 4Matic & W140 1998 S600 V12
What have you done finally? I removed the 1st muffler(it's not a resonator) on my 600 and it did not change anything because the second muffler is pretty restrictive and muffles the sound really well. Also when I removed the second muffler and left the first one on, it made a BIG difference because the only thing remaining are the cats (does verry little effect) and the first muffler which is a straight through perforated muffler. Therefore the sound left is loud but sounds a very mellow "woohwhooo" ish with no rumble. I'm planing to go with 2 flowmasters (either 40 delta or 50 delta) with no muffler at all so I can keep (accentuate) the rumble. If it's too loud on idle 2 bullet sort staight through mufflers will do the job of quieting the sound at idle but will keep the roar.
What are your plans/have done?
ps. 2 x 2.5 NO MORE!!!!!!!!!
2.25 is ok specially if you don't floar it past 5k rpm
