S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Central Locking System
Old Aug 21, 2011 | 11:06 AM
KirkKirkland's Avatar
1995 E320 Wagon
I have a 1999 S320 which everything worked fine when I purchased it; then I changed the batteries in the keyless remote and everything stopped working (Doors and trunk locks) any suggestions? I have unhooked the battery and nothing changed.
Old Aug 22, 2011 | 06:54 AM
oldsinner111's Avatar
s320
with mine I first put key in ignition,then prees to open and hold till door locks or open.
Old Mar 25, 2016 | 01:18 AM
tomsantos's Avatar
1997 MBZ S420
Same thing happened to me.Replaced 2 batteries in my remote key. Made sure of battery orientation (+, -) . Didn't work. Bought batteries from__________. Long story short, removed new batteries and tested for voltage. Found out that one of the batteries has wrong polarity. I'm serious. Must have fried the internal components of remote. Now, my doors and trunk locks do not work, console lock/unlock switch not working. My other remote key elicits green/red flash of light on signal receiver on outside of door. will try disconnecting car battery or pulling several fuses out and put them back in, hoping things will reset. Will post results.
