S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Idiot light for replacing bulb. Help!
Old Jul 2, 2003 | 03:52 PM
Raul J. Carrasq's Avatar
1994 S320
The Replace bulb light on the dash board comes as soon as press the brake pedal. I went the dealer and bought a set of original bulbs and replaced them nad the light still came on. They checked it and told me that they could not find what it was and that the only thing that could be doing this was the ABS Control Module. Can someone help me with this.
Old Jul 9, 2003 | 10:13 PM
kkwhung's Avatar
My dad's old 94 S500 had that problem and it never really went away or fixed by the dealer. The dealer's guess is it's probably bad contact with one of the bulb in one of the brake lights.
Old Jul 10, 2003 | 09:24 AM
1994 S320
Thank you for the reply. I wonder if there is a way of fixing it by tightening the contacts in the brake lights. Anyhow, thank again.
Old Jul 11, 2003 | 12:39 PM
RapidG's Avatar
C32AMG
Brake Light
The most common reason for the idiot light to come on when the brake is depressed is a burned out third brake light on the back shelf. Have someone look at that light while you press the brake.
Old Jul 11, 2003 | 06:20 PM
1994 S320
Thank you for the tip. I am going to check it this weekend. Lets see if that is the reason why it's coming up. Anyhow, thank you again and I will let you know what happens.
Old Jul 15, 2003 | 01:10 PM
1994 S320
I checked the third brake light on the car and it is fine. Any other of what could be cousing this? suggestions, anyone?
