S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
2000 E-320. ABS, BAS, ESP - Engine Shutoff
Old May 10, 2012 | 10:55 PM
Autolizer/MB's Avatar
97 S-320 MBZ, 00 E-320
This is an amended findings about the ABS,BAS,ESP warnings then shut off engine unexpectedly. Tried to start, no crank. Have to wait at least half hour then re-start and run w/o problem. Reaching at least 6 to 7 miles
ABS,BAS,ESP appeared then shut off engine again unexpectedly. Thanks guys for the note that it could be the "CPS" affecting the engine. No brake fluid leak. OBD find everything normal. Looking forward for more infos. Thanks
Old May 15, 2012 | 12:35 AM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
try using a star instead of an OBD which won;t tell you much of anything.
