S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
floats like a boat
Old Jul 15, 2003 | 03:11 PM
shmelvin's Avatar
none
floats like a boat
My 1993 600SEL tends to float and be some what bouncy over highway bumps. I tried the standard push down on the shock test, but this tank wont budge. When I asked the dealer they said the shocks look fine but would gladly replace them, As far as I can tell there are no aftermarket shocks for the adaptive dampening system. But Bilsteins make them in a standard configuration. Can and or should they be replaced with out the OEM system?
Any opinions??????????
Old Jul 15, 2003 | 03:29 PM
///S320's Avatar
S320W
Re: floats like a boat
Try 18 or 19" AMG wheels with atleast 255/45-18 or 19 to improve handling.
Old Jul 15, 2003 | 05:53 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
If I remember correctly, there is a button on the cluster to change the damper mode to firm or soft on the S600 or 600SEL.
Old Jul 17, 2003 | 11:26 PM
kkwhung's Avatar
All the W140 floats, and as it ages, the problem will get worse (at least when we had our S500). The S600 do have the ADS system (the button with a shock icon) that will stiffen up the suspension, so you should try that and see if that helps.
