S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
shaking like mad
Old Jul 18, 2003 | 03:02 AM
RD Sport's Avatar
C200 Kompressor, S320
shaking like mad
My car has 18' AMG monoblock with Dunlop SP9000 245/45/18. The tires have traveled more than 25000km. Now, when my car travels at 82-87km/h. My steering wheel is shaking like mad and the passengers can feel the shaking. But this only happens between 82-87km/h. Otherwise, it is very smooth and no shaking at all. I am now running tires pressures (cold tires) 34 fr and 37 rear. What do you guys think?
Old Jul 19, 2003 | 01:24 AM
barry S320V's Avatar
1995 S320V
shake
So:
You have the wrong size wheels, the wrong size and make of tires and your tire pressure is way too high. I wonder why you are having problems?
Barry
Old Jul 19, 2003 | 03:03 AM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Well, Hong Kong has narrow streets, if you hit the curb often, you might want to check the balance of each wheel more often. Also, I would switch to smaller size tires over there.
Old Jul 20, 2003 | 04:30 AM
wmak8's Avatar
You have bent a rim. Have a wheel and tire shop check it out for you. Hopefully, he can get rid of some of the shaking by re-balancing. Otherwise, you will have to repair or buy a new rim to get rid of the shake. This happened to me before. If the rim is bent, no matter how you have it re-balanced, it will still shake.
Old Jul 23, 2003 | 04:04 PM
alz's Avatar
alz
Get your wheels balanced
Classic problem -- will be fixed quickly (unless a tire is out of round whihc seems unlikely given the current mialge).
