S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Function Chain??
Old Aug 29, 2012 | 04:11 PM
ccuffaro's Avatar
1996 MB W140
Function Chain??
Hi Gang,
I'm a new MB Guy. BMW Convert.
Just picked up a 1996 S500 with 85,000 miles on it. I have replaced Plugs, Air Filter, Fuel Filter and MAF Sensor. I am getting the following error codes and not sure what to do next.
0170 Right cylinder mixture adaptation reaches limit
0173 Left cylinder mixture adaptation reaches limit
0410 Secondary air injection malfunction function chain
1519 Camshaft timing function chain
Any thoguhts would be great. Thanks
Old Sep 13, 2012 | 07:43 AM
oldsinner111's Avatar
s320
the chain may cause problem.The oil pump chain can go south in 500 engines.
Old Oct 28, 2012 | 12:45 PM
eddie a's Avatar
94 S420,95 S500 ,96 S500
The chains dont break the Timing chain Guides get brittle and break into pieces which makes things bad..
