S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Need help with interior temp sensor
Old Oct 8, 2012 | 10:46 PM
kcscout's Avatar
97' S320 & 00" S500
Can anyone tell me how to change the interior temp sensor on a 97 S320. I have no heat and I used directions found on a forum to read the codes from my climate control. Code 01=LO which tells me that the interior temp sensor is either shorted out or just failed. I have no idea where to find that sensor or how to replace it. Can someone help me with that. Oh yea and it would also be helpful to know where I can get one too.
Old Oct 22, 2012 | 11:57 AM
kcscout's Avatar
97' S320 & 00" S500
Well, I did not get any responses to this inquiry, but I did some research in this forum and found out that the interior temperature sensor is in the overhead unit that includes the front cabin light. After removing the cover I found the electrical connector for this device to be loose. I plugged it in and it now reads normally. That is just dumb luck. I still don't have any heat though and I am now trying to diagnose the duo valve. if anyone has disgnostic procedures for that valve please post them here.
