S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Seat Belts Not Working
Old Nov 4, 2012 | 10:07 PM
simark13's Avatar
'99 S500 (W140)
Hey people, the drivers seat belt and front passanger seat belt do not roll back up, does anyone know what I need to do or where I can get the new necessary parts for this??
Old Nov 5, 2012 | 03:46 AM
oldsinner111's Avatar
s320
You might try dealer or Autohauz. there a 150 each I believe
Old Nov 5, 2012 | 09:15 PM
simark13's Avatar
'99 S500 (W140)
Cool, thanks for the info
Old Dec 16, 2012 | 10:45 PM
kcscout's Avatar
97' S320 & 00" S500
Check on eBay. There was an ad for seat belt repair for MB's. The price was $65 I think.
Old Jan 17, 2013 | 06:33 AM
eddie a's Avatar
94 S420,95 S500 ,96 S500
There is a cable under the seat that comes from the seat belt. It clips on and if it pops off as some do your seatbelts would not work properly. You can lift the seat up high in the rear and look for it..it is on the outer side of the seat on both sides. a clip hold it on..check that before you buy a new one..
Old Jan 24, 2013 | 08:19 PM
kcscout's Avatar
97' S320 & 00" S500
My front drivers belt stopped retracting and I send it to a shop in SC that advertised on eBay. They rebuilt the mechanism for $60 (including one way shipping) and now it works perfectly. The place is called "Safety Restore" They rebuild seat belts and air bags. This worked well for me.
Eddie A: I did see the cable you mentioned. It was intact so that was not the problem. The coil spring in my seat belt mechanism was just worn out from 12 years of use.
